I've not a found an all inclusive conversion chart yet - I use mostly google and alta-vista searches with lots of checking results. SCM415 seems to have no direct ANSI equivalent but I saw AISI 4115 and 4118 mentioned.
ANSI does not maintain standards regarding steel. This is done by ASTM or SAE. The following link identifies several excellent references for equivalent steel grades:
