1
- #1
I modelized a friction damper in Abaqus.
So, I created the job and I submitted.
Therefore, after moments, I looked at the monitor and noted that I these errors :
in keyword *CLOAD, file "H-shape1.inp", line 177647: Unknown part instance set BOLT(M36)-1."_Pretensioning Bolts_blrn_"
in keyword *CLOAD, file "H-shape1.inp", line 177647: Unknown part instance set BOLT(M36)-1-LIN-1-2."_Pretensioning Bolts_blrn_"
in keyword *CLOAD, file "H-shape1.inp", line 177647: Unknown part instance set BOLT(M36)-1-LIN-2-1."_Pretensioning Bolts_blrn_"
in keyword *CLOAD, file "H-shape1.inp", line 177647: Unknown part instance set BOLT(M36)-1-LIN-2-1-LIN-1-2."_Pretensioning Bolts_blrn_"
in keyword *CLOAD, file "H-shape1.inp", line 177647: Unknown part instance set BOLT(M36)-1-LIN-1-2-1."_Pretensioning Bolts_blrn_"
in keyword *CLOAD, file "H-shape1.inp", line 177647: Unknown part instance set BOLT(M36)-1-LIN-1-2-LIN-1-2."_Pretensioning Bolts_blrn_"
NODE SET ASSEMBLY_BOLT(M36)-1__Pretensioning Bolts_blrn_ HAS NOT BEEN DEFINED
A CONCENTRATED LOAD HAS BEEN SPECIFIED ON NODE SET ASSEMBLY_BOLT(M36)-1__Pretensioning Bolts_blrn_. THIS NODE SET IS NOT ACTIVE IN THE MODEL
NODE SET ASSEMBLY_BOLT(M36)-1-LIN-1-2__Pretensioning Bolts_blrn_ HAS NOT BEEN DEFINED
A CONCENTRATED LOAD HAS BEEN SPECIFIED ON NODE SET ASSEMBLY_BOLT(M36)-1-LIN-1-2__Pretensioning Bolts_blrn_. THIS NODE SET IS NOT ACTIVE IN THE MODEL
NODE SET ASSEMBLY_BOLT(M36)-1-LIN-2-1__Pretensioning Bolts_blrn_ HAS NOT BEEN DEFINED
A CONCENTRATED LOAD HAS BEEN SPECIFIED ON NODE SET ASSEMBLY_BOLT(M36)-1-LIN-2-1__Pretensioning Bolts_blrn_. THIS NODE SET IS NOT ACTIVE IN THE MODEL
NODE SET ASSEMBLY_BOLT(M36)-1-LIN-2-1-LIN-1-2__Pretensioning Bolts_blrn_ HAS NOT BEEN DEFINED
A CONCENTRATED LOAD HAS BEEN SPECIFIED ON NODE SET ASSEMBLY_BOLT(M36)-1-LIN-2-1-LIN-1-2__Pretensioning Bolts_blrn_. THIS NODE SET IS NOT ACTIVE IN THE MODEL
NODE SET ASSEMBLY_BOLT(M36)-1-LIN-1-2-1__Pretensioning Bolts_blrn_ HAS NOT BEEN DEFINED
A CONCENTRATED LOAD HAS BEEN SPECIFIED ON NODE SET ASSEMBLY_BOLT(M36)-1-LIN-1-2-1__Pretensioning Bolts_blrn_. THIS NODE SET IS NOT ACTIVE IN THE MODEL
NODE SET ASSEMBLY_BOLT(M36)-1-LIN-1-2-LIN-1-2__Pretensioning Bolts_blrn_ HAS NOT BEEN DEFINED
A CONCENTRATED LOAD HAS BEEN SPECIFIED ON NODE SET ASSEMBLY_BOLT(M36)-1-LIN-1-2-LIN-1-2__Pretensioning Bolts_blrn_. THIS NODE SET IS NOT ACTIVE IN THE MODEL
Can you tell me how to fix these errors please?
