Struct1206
- Apr 29, 2009
- 37
In my experience, it is typical in a structural engineering office to have several tiers of engineering staff. At the bottom, there are EIT's and young engineers; then above them you have mid-level engineers who have their PE's; and at the top you have Senior Engineers/Principals/Owners, etc. Typically, I have not seen anyone below the top tier have the ability/responsibility of reviewing and stamping drawings. It was always left up to the principals to review/oversee the work of the work of the younger engineers. My thought is that there are distinctly different responsibilities and pay scales at each level or tier. This seems reasonable correct?
If a company was to employ only a single structural engineer, who had to review and stamp his own work without any oversight, what would you say the minimum requirements for that position would be? ie. Is it reasonable to put someone who just passed their PE into that spot? Would that position command the same salary as someone in a larger engineering group with an equal amount of experience? Let's say that the engineer doesn't have an extensive amount of experience (4-8 years). At a larger company this person would be a mid-level engineer that worked under a senior engineer, would you say that the expected salary of these two positions would be different? Why or why not and to what extent would you expect the salary to differ.
I know this might seem silly to some but it has been bugging me and I'd really appreciate some input from some other engineers.
Thanks,
Thanks,
