fedefer85
- May 31, 2017
- 11
Hello. My case is a pressure vessel with no design data (0,70 by default). An ultrasonic inspection of welding were performed in order to increase this value. However, there were found laminations in shell, reaching the shell-head weld, so increasing vessel joint efficiency is not that easy.
Does anyone know if there is a table of joint factors for welds with defects, or something similar to that? If it not, it seems like it won't be able to has a joint factor greater than 0,70.
