LS_SMS
- Sep 18, 2020
- 108
Folks, I'm using v2022R2 Mechanical. Is there a way to get joint reactions in Solution Combination? I don't see a RMB option for it.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I believe you are referring to User Defined Result (UDR). I tried that today, but I had no success. I'm using v2022R2. At that version, there is no way to scope the UDR to the joints. I learned that that feature came available at v2023R2.STpipe said:The workaround is to introduce a custom solution (I forget the exact term), and call out the correct SMISC number associated with that type of result in the database.
No, that will not work either. On Solution Combination, there is no RMB option to insert Command Objects unfortunately.STpipe said:Another option would be to introduce an APDL command object and script using apdl commands to take a print screen of the model with the reactions displayed. You could also setup that same script to export the results to a text or csv file for further post processing.
