I'd like to do a survey to find out what published tables are available for aircraft fastener joint strengths. We typically use MIL-HDBK-5H and Boeing SRM tables for proven (tested) values for rivets, Hi-Loks, screws, etc. However, I often come across combinations of fastener/sheet materials for which I can find no published test values. Part of the problem lies with working on older aircraft, but there must be other data available somewhere.
