Journal for Save As in IGES Format
shan89
Automotive
Dec 14, 2012
19
I need a journal to save as assembly files in IGES format in the working directory itself.
I tried to create one looking at some existing journals, but unable to complete my journal. I know nothing about computer languages, so I could be wrong at many or all points.
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim fileName As String = IO.Path.GetFileName(workPart.FullPath)
Dim fileNameNoExt As String = IO.Path.GetFileNameWithoutExtension(workPart.FullPath)
Dim parentFolder As String = IO.Path.GetDirectoryName(workPart.FullPath)
Dim root As String = IO.Path.GetPathRoot(workPart.FullPath)
Dim thepath As String = "fileNameNoExt: "
Dim PartExt As String = ".igs"
Dim displayPart As Part = theSession.Parts.Display
Dim partSaveStatus1 As PartSaveStatus
Try
partSaveStatus1 = workPart.SaveAs(thePath+displayPart.Leaf+PartExt)
partSaveStatus1.Dispose()
Catch ex As Exception
End Try
End Sub
End Module
However after running this journal, no error came but no file was created as well.
Thanks in advance,
Ishant
Hi ,
Try to change the line :
by this line :
partSaveStatus1 = workPart.SaveAs(IO.Path.GetDirectoryName(workPart.FullPath) & IO.Path.GetFileNameWithoutExtension(workPart.FullPath) & ".igs")
Thanks for the help, this journal is running now and creating the iges file on desktop. But I want the Iges to be created in the working directory itself(wherever the part files are placed).
Thanks for your support!
completed the journal with little change on following line:
to:
partSaveStatus1 = workPart.SaveAs(IO.Path.GetDirectoryName(workPart.FullPath) & "/" & IO.Path.GetFileNameWithoutExtension(workPart.FullPath) & ".igs")
