Journal to delete all object on layer 201 in active drafting sheet only 1
danuvi
CH
I need to delete all objects on layer 201 in the work-active drafting sheet. I have found a good journal to begin with (It delets everything on layer 201 in the whole part). The problem is, if I have multiple drafting sheets it deletes the objects on layer 201 everywhere. I have completely no idea how to solve this problem. I hope someone could help me with this. :D
Code:
Sub Main
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim displayPart As Part = theSession.Parts.Display
        If displayPart Is Nothing Then
            Exit Sub
        End If
        Dim notifyOnDelete1 As Boolean
        notifyOnDelete1 = theSession.Preferences.Modeling.NotifyOnDelete
        theSession.UpdateManager.ClearErrorList()
        Dim nErrs1 As Integer
        nErrs1 = theSession.UpdateManager.AddToDeleteList(workPart.Layers.GetAllObjectsOnLayer(201))
End Sub
Try this. Below method will help you.
Conditions:
1. Objects must not be a hidden object.
2. Open the drawing sheet and run the journal
Code:
using System;
using NXOpen;
public class NXJournal
  public static void Main(string[] args)
            Session theSession = NXOpen.Session.GetSession();
            Part workPart = theSession.Parts.Work;
            // Set the layer No.
            int layerNo = 201;
            NXOpen.Drawings.DrawingSheet currentSheet = workPart.DrawingSheets.CurrentDrawingSheet;
            NXOpen.Layer.State state = workPart.Layers.GetState(layerNo);
            if(state != NXOpen.Layer.State.Selectable)
                workPart.Layers.SetState(layerNo, NXOpen.Layer.State.Selectable);
            currentSheet.View.Fit();
            DisplayableObject[] sheetObjects = currentSheet.View.AskVisibleObjects();
            theSession.UpdateManager.ClearDeleteList();
             NXOpen.Session.UndoMarkId markId1;
            markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Delete");
            foreach (DisplayableObject item in sheetObjects)
                if (item.Layer == layerNo)
                    theSession.UpdateManager.AddToDeleteList(item);
            theSession.UpdateManager.DoUpdate(markId1);
            workPart.Layers.SetState(layerNo, state);
  public static int GetUnloadOption(string dummy) { return (int)Session.LibraryUnloadOption.Immediately; }
Thanks SelvarajC, you just made my day :D
Exactly what I was looking for. Works great
I however changed it to VB...
Heres the code if anyone finds this Post again.
Code:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
		Dim theSession As Session = NXOpen.Session.GetSession()
		' Set the layer No.
		Dim layerNo As Integer = 201
		Dim currentSheet As NXOpen.Drawings.DrawingSheet = workPart.DrawingSheets.CurrentDrawingSheet
		Dim state As NXOpen.Layer.State = workPart.Layers.GetState(layerNo)
		If state <> NXOpen.Layer.State.Selectable Then
		End If
		Dim sheetObjects As DisplayableObject() = currentSheet.View.AskVisibleObjects()
		Dim markId1 As NXOpen.Session.UndoMarkId
		For Each item As DisplayableObject In sheetObjects
			If item.Layer = layerNo Then
			End If
		Next
	End Sub
	Public Function GetUnloadOption(dummy As String) As Integer
		Return CInt(Session.LibraryUnloadOption.Immediately)
	End Function
End Module
