Journal to Select FlatSolid
BBow
I have an existing journal to work through an assembly and extract bounding box information for each component in the assembly for BOM purposes. This works well except for formed components, where we want to bound box only the FlatSolid of the component. Does somebody know the code to do this? Find and select the FlatSolid only.
The following journal shows one way to do it.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim theUI As UI = UI.GetUI()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "find flat solid")
        lw.Open()
        Dim myFlatSolid As Body = Nothing
        For Each tempBody As Body In theSession.Parts.Work.Bodies
            Dim parentFeats() As Features.Feature = tempBody.GetFeatures
            For Each tempFeat As Features.Feature In parentFeats
                If TypeOf (tempFeat) Is Features.FlatSolid Then
                    myFlatSolid = tempBody
                End If
            Next
            lw.WriteLine("")
        Next
        lw.WriteLine("flat solid body tag: " & myFlatSolid.Tag.ToString)
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
Thank you sir!
Helpful as always
