vincentpa
- Nov 9, 2005
- 223
For steel braced frames, what is the maximum aspect ratio (bay length/story height) that you would use for X-braced frames? What is the maximum aspect ratio you would use for K-braced frames? When do you typically use each one (i.e. in which situation would you choose K-bracing over X-bracing)? I am designing a building with a 40' bay and a 15.5' height. What drift limits do you typically use, 0.0025 x story height?
