The bridge I’m working on has a radius on the off end to allow traffic to turn off the bridge. A kicker beam will be used at the end of the bridge to carry the additional deck required for the radius. The main fascia girder the kicker will frame into is a two span continuous steel girder and the kicker will frame in at about the 1/4 point of the fascia girder.
My question is does any one know of any references or have any advice for determining the distribution of the LL to the kicker beam and main girder (or any general references for this situation)?
Also, any thoughts on the design of the connection between the kicker and fascia girder would be appreciated. This will most likely be a simple shear connection. I’m not sure how thermal movements and other longitudinal force will play into the connection design. The abutment end of the kicker will be an expansion bearing.
Thanks in advance for sharing your thoughts.
