kit car torsional stiffness question (with a twist!) 1
dexion7
Automotive
Dec 8, 2010
26
my car is a kit car with no roof so the torsional stiffness of the chassis if probably quite low. it has an engine making about 450 lb ft of torque which probably tests the chassis, particularity in the lower gears. however, it's 4wd so i wondered if the torsional load exerted on the chassis would be mitigated by the torsional load at the other end of the car?
However the drive is split, the front transaxle is likely bolted to the motor, so about 1/2 of that torque will be taken up between the two, and the assembly will want to rock around the transaxle. The other 1/2 will be multiplied by the drive ratio and transmitted to the rear differential and resisted by the frame.
the front diff is not mounted to the engine, its bolted to the chassis. the rear diff is likewise bolted to the chassis at the rear. the car has wishbones on all four corners - no transaxles.
A car can have wishbones and a transaxle.
Is there a driveshaft between the front differential and the transmission? If the answer is no, that's a transaxle.
Either way, the engine and trans will apply a moment to the chassis.
all corners have double wishbone suspension. there is a drive shaft from the transmission to the back diff and another drive shaft to the front diff from the transmission. there is a centre differential which splits the torque 60/40.
my question is, will the effect of having drive to both ends mitigate the chassis twisting which would likely occur in a similar 2wd car?
That sounds likely. You could do a free body diagram and see what that tells you. The arrangement sounds easier to draw and FBD than to sort out by discussion. Observe the rotation of the different drive and output shafts to determine the correct sense of torque.
well both drive shafts turn in the same direction if that's what you mean?
obviously, so do both pairs of half shafts!
So you've got an engine and transmission unit bolted such that the engine's torque reaction comes out somewhere along the chassis' X-axis and two differentials bolted at two other locations. Sounds like a parallel combination of springs in series, especially given the anticipated [low] magnitude of chassis torsional stiffness.
Norm
the diffs are solid mounted and the engine/transmission unit is mounted on rubber mounts.
is the parallel combination of springs in series suggesting that the chassis twist will be mitigated or not mitigated?
No matter what the directions of the various moments are, the total imparted to the hard points in the chassis will not be zero, if that's what you are asking.
You'll also have couples between them.
Let's simplify the problem. We are concerned about the body twisting between the front and rear halves. The engine and front differential are in the front half. Any torque supplied to the front wheels will reduce the torque to the rear of the car, so twist of the body will be reduced.
well that's the same as reducing engine torque but doesn't address the question!
The answer to your question is no.
The motor mounts/transmission mount still have to resist the full moment put out by the engine/transmission.
The car has no roof. The OP's concern is with twist of the chassis due to this fact. The engine and transmission mounts are not a factor in this. They are only relevent to twist in the front half of the car, not twist between the two halves. A front wheel drive car can drive without a back half.
The actual configuration of the alleged car is so far not in evidence.
Mike Halloran
Pembroke Pines, FL, USA
The powertrain exerts forces at the points where rotation is resisted, i.e. at the tyres and at the engine mounts. For a longitudinal (north-south) engine,the mount forces will give a twisting torque on the chassis, reacted by vertical forces through all the tyres. Nothing else matters. A simple thought experiment involving a transverse engine might help.
Steve
Are there, on TEH INTERNET! any pictures, complaints of said kit car, built per mfg instructions shown twisted up, with rippled body panels, cracking at stress risers, shedding paint, or with doors that closed properly when made, but not any more, or other evidence of damage related to winding the motor up all the way in 1st gear (max driveshaft torque)?
If not, and the there is a reasonable existing fleet of this kit, then I'd say a free body diagram would raise and answer similar and interesting questions to those that were addressed in the design phase of the kit.
this is the car but i'm not sure how it helps you.
its a dax rush which is a copy of the original Lotus 7 from the 60's. there are many kit car companies who made copies of the Lotus 7 varying from good to shocking. the Dax Rush was designed from the outset to support high output engines and has significantly more chassis members and gussetts than other types. i understand that around 500 2wd versions were made but only around 10 4wd like mine. i'm not aware of any of them cracking thier chassis like you mention and there is no evidnece of that on mine. i think that the torque output of the engine in mine is higher than most of them, 2wd or 4wd.
some time ago i recall someone posting a video of thier car (not a Dax Rush) and they had mounted a camera on the rear looking forwards with a ruler sat on top of the windscreen. it was possible to see chassis deflection on that basis and this is what made me consider the situation in my car. i could try the ruler thing but imagined that an expert opinion from someone on here would be easier.
i dont know what a free body diagram is but can provide any information required
 http://files.engineering.com/getfile.aspx?folder=05562f32-c6d2-4752-b5eb-912442e3bd05&file=dax.docx
You could talk to the people who know it best- the manufacturer and other owners, and see what the record is regarding installed power, usage and structural performance. Ideally, you'd want to find someone who put a bigger motor in, and races it every sunday for the past 5 years, and has had no frame problems.
Without knowing details and going through the design I don't think any one of us could give an analysis in a short amount of time that we're prepared to have someone else risk their safety over.
I think the history of a couple similar and heavily used cars could tell you more than all of us.
