Does anyone have experience with cracking of the X knife blade assembly on reverse buckling, large (>24"dia) rupture disk designs in saturated steam service?
The blade ends are fillet welded to the inside wall of the disk holder and the cracks appear parallel to and 1/4" away from the fillet weld toes. The crack at one end of each blade usually goes through wall while the crack at the other end does not, indicating a thermal fatigue mechanism.
The blades are above the disk and see ambient atmospheric conditions in the vent while the holder sees process conditions (60 psig at 306 degF). The warm-up thermal transient would rapidly heat the holder with condensation heat transfer, which would stretch the blades and probably initiate cracks. The blade thickness is constant but the blade depth increases from the holder wall to the X weld.
The holder is A105 and two blade materials have been tried; A505 4130 and ATI PH7-17 and both have cracked. The blade X assembly is heat treated to maximize hardness, then welded into the insert. Perhaps localized annealing is required at the fillet welds?
