Knurl on cylindrical surface 1
tduong
7
How can I create a knurl cut on a cylindrical surface? in the part modeling. Please help.
Why would you want to waste your time modeling a knurl. I would just add a surface texture. Are you using Wildfire or Pro/E 2001?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
I agree with Heckler. There is no need to show an actual knurl on a surface, unless it is for a photorendering or some other type of presentation. Adding such features with actual cuts only helps to slow down your regen time.
If you really, really, really need to make a knurl (diamond shape I assume), then you can project or revolve a datum curve around the cylinder surface, then make a swept cut and then pattern the datum curves and cuts. Do the same thing for the other direction.
There are other ways to do it with surface also.
Steve
One other way to go about it is with a helical sweep. Make sure you sketch the sweep profile on a Make Datum that is offset at an angle, as this will allow you to pattern it radially. You will need two patterns, one from a right handed helical sweep, and the other left handed. It's basicaly the same thing as Steve's suggestion.
I also agree with Heckler though, knurls make for slow regenreating models. Applying a texture with a bump map would probably be the best way to go about it.
Thank you for all your help. I agree. the surface texture is the best. I am using ProE wildfire 2. How can I create a surface texture on cylindrical surface. Please advise.
Thanks,
