Konica 7020
sfb42
3
Hi there
I just installed a Konica 7020 copier/printer to my PC. I can print from any other application except Autocad. I have the 2006 version of Autocad installed.
Any suggestions??
Go through the Plotter Manager in AutoCAD and add that printer. Most likely start with "Network Plotter Server" type of setup and use something like HP 5000 driver or such. If that does not work, try another driver till you find a good one.
"The fear of the Lord is the beginning of wisdom"
Already did that. I also tried with some more HP Printers, but nothing happened.
The strange thing is that the printer doesn't receive any commands. Nothing happens.
Any suggestions??
Directly connected to my computer via a parallel cable on LPT1
