This question is baffling me ever since I am working in this crane.
This crane lifts containers of max. load 40T. It uses rectifier-drive for control of all motors. The kVA rating of the diesel generator set is 670kVA. CAlculating the max kVA load including all auxillary drives, it comes to 301kVA.
The only thing that I have some doubt is - when the load is lowered the regenerated energy is diverted to a resistor bank to be dissipated as heat. But the resistor bank gets the dc from dc bus only as the rectifier cannot send it back to the ac input side.
So, this high difference between generator capacity and load is due to what reason?
D'man
D'man
