Eliz2697
- Nov 17, 2015
- 6
My issued is the following:
The hydrocarbons that we are going to handle are Gasoline, Diesel and LPG.
The tests to apply to these hydrocarbons are to determine la quality of the product.
In these areas where the samples are storage, handle, prepare, etc. Is need it a air conditioning system. this unit need to be a 100% air fresh or a simple Air contioning handling unit. I know that I need to have Fume hoods, Is this system (Fume hood exhaust)independient of the air contiotioning system,
My worried is because I need a negative pressure in these areas due to avoid flammable gases go to non-laboratory areas (What is the desing pressure in this case where I can get the value of that negative pressure in a standard).
It is necesarry to have fire-smoke dampers in this desing.
What are the conditions of temperature, pressure, humidity, etc, that I need in these kind of laboratory. There is a table in a standard or what?
Please I need some much your help.
