electricpete
We have a small (5hp?) TENV crane motor in outdoor application, approx 2 years old. We recently heard lots of vibration. Investigated and found that the drive end had apparent moisture intrusion. Shaft and external bearing surfaces inside motor showed early signs of rust. Bearings are double-shielded (require no lubrication).
Inspection shows that shaft penetrates the end bell and there is no lip seal or slinger ring or anything (other than close clearance between housing and shaft) to prevent moisture entry. There was however grease in the end bell bearing cavity, which is strange since it's a double-shielded bearing. Called manufacturer who told us that the grease is intended to stop the entrance of moisture around the shaft, and we should replenish it to solve the problem.
That sounds pretty hokey to me. What do you guys think?
