Mohit Jain
I have generally designed ladders for 300 lbs load acting on rung. I researched a bit. It looks like ladder has to be designed for 2700 lbs (by manufacturer) acting at location of fall arrest system. I wanted to ask do we need to design anchors connected to wall/ nailing connected to wood block which acts as a support for side rails for reaction due to such high load in addition to rung and side rail design?
Also, If my ladder extension is 4.0 ft from the last anchor support. Do, I need to check minor direction bending as well for 100 lbs load and will rung acts as brace for side rails? The rail extension will be 4.0 ft in major direction. Will it be distance of extension from last rung or last anchor support for bending in minor direction check?
