If a lag screw penetrates fully through the side member, is there still and 4D min penetration requirement for lateral load or is using the side member thickness for bearing okay (i.e. using 3/4" dia lag through 1-1/2" wood side member where 4D min would be 3" but the side member is only 1.5")
Thank you for any clarification on this
