I am trying to simulate the effect of gravity on an object (breast). The breast under-goes large deformations because of gravity, the pendulum length of breast almost doubles between the positions am interested in.
Initially I used static, general analysis and I got error "Error in job Job-1: Time increment required is less than the minimum specified".
Then I used to explicit analysis and I got result i.e. deformed breast which looks sensible. But it leaves me with a question whether my analysis is valid or not. Attached is plot for IE and KE, the KE/IE is not in the recommended range of 1-5% for most part of the analysis. In this curve I dont understand is why is the energy profile oscillating.
To understand the difference between standard and explicit, I drew and meshed a hemisphere and assigned it properties of breast tissue and applied gravity to it using standard and explicit analysis separately. Between the two analysis, I found that the deformation are quite similar though there is difference in the magnitude of deformation by about 5-20%. In explicit analysis again KE & IE had oscillating profile and the KE was not in the 1-5% of IE.
Any comments and guidance would be very helpful.
Prab
Prab
