Got a question for all of you fine folks....
Here's the scenario:
I've got a well station being constructed and the design used 180 feet of 48 inch DIP for the chlorine contactor. The pipe is arranged in a "U" shape, fairly level and we used TR Flex joints.
The contractor is having difficulty getting this pipe to hold pressure. The line is filled, and when the contractor pumps it up to 200 psi, the pressure drops down to 150 psi within 15 minutes. Several taps were made along the line to provide a means for letting air out of the pipe.
We had our leak detection crew out to the site to sound off the pipes, but they were able to find anything worth looking at.
The contractor has exposed joints and even removed a thrust block to inspect the back of a 90 degree fitting since their experience has been that pinholes are not a completely unheard of issue with fittings over the past few years.
I'm looking for other people's experience with such large diameter pipe installations. Is there something that we should be looking for that is a common problem with large diameter pipe? Has anyone heard of any issues with US Pipe products of that size? The contractor had US Pipe out to the site to oversee the completion of the first few joints, and things went well. An internal inspection of the pipe was also made after installation was complete. There were no visible issues.
We've run out of tricks.
Any help is greatly appreciated.
HB -PE Env.
HB -PE Env.
