spieng89
- Jun 30, 2015
- 172
I currently have a situation where column loads of up to 50 kips will be applied to a slab-on-grade (6in thick reinforced). Using the Shentu Method for minimum base plate area and slab capacity, I can get a reasonably sized base plate to distribute the load effectively and avoid punching shear.
My question is should I be worried about differential settlement around this column inducing radial cracks? Would I be better off designing a separate shallow foundation for these columns? The reason they bear on the slab now is the locations are not known, but I was thinking if cracking is an issue I might design a strip footing with isolation joint.
