kcalderwood
New member
I am currently in preliminary design for a new treated effluent discharge pipeline. The new pipeline will likely be in the 42" to 48" diameter, and the downstream terminus will be a connection to an existing 96" RCP outfall pipeline force main, operated by a joint powers agency. The force main owner agency would like the connection to be a 45-degree horizontal wye type connection.<br>
<br>
I would prefer to make the connection without shutting down the 96" outfall pipeline. Does anyone know if a wet-tap type connection can be made at a 45-degree angle, at this size? I anticipate that we will have to spec some kind of custom tapping sleeve or concrete connection collar, but I'm not even sure that tapping equipment exists that can do what I want.<br>
<br>
Thanks for your help.
<br>
<br>
