daxman1
Aerospace
- May 18, 2018
- 16
I have been doing some research on laser cutting and although it is a great option in many cases it may not work for aluminum. We are looking at sending out some aluminum parts to be formed. The parts are approximately 2' by 2' made from 2024-T0 material .032 thick. The material is currently hammer formed (this may be hydro formed at the new vendor) then heat treated to T3.
The vendor has asked if they could laser cut the parts. Everything I have read states that lasers do not cut copper and aluminum well because of their reflective and heat conductive properties. I have also been told that it can cause brittle edges that can cause stress risers if not reworked. I believe the vendor knows what he is doing but I'm hoping some here can enlighten me as to laser cutting aluminum.
