Laser Shaft alignment Pump, gearbox input outputand motor 1
bmw318be
197
Hi
I have some doubts on laser alignment of pump to gearbox and Motor.
While aligned the pump and geaebox, after vertical adjustment is within tolerance, I moved to the horizontal alignment while leaving the vertical bolt snugged.
Thw result,after horizontal adjustment, the remeasured show the Vertical is out of tolerance.
Is there a tips should i add shims make it slightly higher before torque it down.
It just did not get consistent alignment after every horizontal adjustment.
