Latching/Reset pneumatic push button valve
MartyMW
3
All,
I am new to pneumatic controls and am looking to see if a component I need is available off the shelf.
I have a pneumatic process valve that is maintained open via soloeniod valve connected to a pressure switch (high pressure closes valve). I need to add a latching function so that the valve will not re-open after a high pressure event until a manual reset valve is pushed. For historical reasons, it would be easiest if that reset function operated pneumatically instead of electrically (all components in hazardous area and sealed).
Is there a 3/2 pushbutton pneumatic valve with a latching/reset function built in?
I could achieve this with multiple components but am hoping that this is a common enough function to available as an integrated component.
Thanks,
Marty
Try these guys:
______________________________________________________________________________
This is normally the space where people post something insightful.
How about a non-return valve and a manual vent before the valve actuator.
