ErimusOilnGas
Petroleum
- Mar 13, 2013
- 4
Hi I am trying to get a value for latent heat of a mixture. I require the latent heat to use in W=Q/L to give me a required relief rate.
I have a few questions which noone can really seem to answer :
1 - If i copy my stream and set vap fract to 0.01, the mass heat of vap displayed in the properties tab for that stream. Is this the latent heat for the mixture or just the lightest component?
2 - In thinking method 1 was not correct I copied the stream set it to operating conditions and then put it through a heat exchanger (as is the case for vapour expansion and relief)I set my outlet to the relieving pressure . Is this the correct methos ... it give a latent heat for the outlet stream which is in the right ball park but im not sure as when i manually change the vap frac of the outlet this doesnt effect the latent heat which i would expect it to do as it is changing the temperature and as such the points at which my mixture will vaporize off.
Please ask if i have not included enough information.
Help much appreciated.
Cheers
Jonny
Cheers
Jonny
