designrider
- Oct 25, 2007
- 50
Lateral analysis - Detailed vs. Simple
When performing the analysis for a Lateral Force Resisting System, typical practice in my office is to calculate both wind and seismic loading conditions for every resisting element independently, then proceed with the design of each element using the controlling load combination by comparing the calculated wind and seismic loading. Thus some resisting elements may be designed for wind, others for seismic.
However, I am aware that others typically only calculate the base shear for both wind and seismic and then proceed in designing the resisting elements only for the loading conditions generated from the controlling base shear force. Thus all resisting elements are either designed for wind, or all elements are designed for seismic.
I would argue that calculating both wind and seismic forces in detail is a more code compliant design (US codes), but in terms of safety I don’t regard designing for the worst base shear to be an inappropriate choice. Any comments on this?
