Lateral Bracing Covered Patio
engineea
9
Hello all,
I have a quick question regarding lateral bracing for a covered patio. In the past I have typically used knee bracing at simple covered patios or even cantilever steel columns/grade beams for larger patios or decks. Are there any other standard options for lateral bracing of structures of this type?
I have a designer who says he has consulted on projects using a knife plate as 'bracing' but he cannot provide a detail or any other info. Has anyone used any other mode of bracing such as knife plates for this application?
Thanks in advance.
I'm afraid you are going to have to determine if it is rigid or not. It looks like it could be flexible or rigid. If you push on a corner of it will it deform or hold its shape? I would think the 12'x12' hole is framed well but I don't know. If its not rigid, I'd probably try to make it rigid.
Thanks for your assistance.
It is much appreciated.
