Converting the top part of a steel grain bin to an open Gazebo. After last night’s wind storm, I’m questioning if the top connected to the posts creates enough of a moment frame to absorb and transfer the lateral wind load. Here in So. Indiana we are in a 90MPH zone.
Diameter is 18’, Side walls are 9 gauge, 2.66” corrugated steel. I’m only using ½ of the top ring, so that’s 18” in height. Roof is conical with a 4.5’ rise (33 degree slope), There are 24 overlapping sections that connect to a 24” open ring for air flow. That will bolt to eight vertical supports that stand 9.5’ above the ground made from 3/8” thick, 4” square steel tube. (4 bolts per post) Footings are 4’ augers with a 12” square base plate on top and a 6” saddle connector to the 4x4.
Load factors for circular and conical structures are hard to find and harder when they aren’t solid like this one. The county building department approved the plans and issued the permit, but….
I’d appreciate thoughts if this will work as described, or do I need to add “beams” between the posts at the top for additional strength? Thanks!
