I have a gravity wall composed of concrete block, the total height will be about 40 feet.
The backfill at the bottom third of the wall will be filled with concrete for a width of 10 feet approximately.
For the stability calculations, I think I can assume some shielding from lateral loads because of the concrete mass behind the wall for sliding by friction.
Can I also assume some resistance against overturning because of the cohesion between the concrete backfill (after setting) and the wall? If yes, what is the approximate value for that cohesion?
