Yazan Atoum
- Nov 4, 2016
- 19
Hello Engineers,
I have a question. For a composite slab I used to design the main girder's bottom flange to be unbraced for its whole length, but one engineer told me that this is extremely conservative and secondary joists with depths around >= 1/3 depth of Girder would provide bracing for LTB even with a shear conncection, I had another debate with a Doctor in engineering, he mentioned that I have to assume the bottom flange totally unbraced for the whole length as there is no such refernce in the codes that assumes a shear connection can prevent LTB, So I am really confused now, I know this would not affect simply supported beam but it does have a remarkable effect on girder with fixed ends or if it's a part of a moment frame where there is an iflection point between positive/negative moment.
Can anyone guide me to a respected reference that gives a solid answer regarding that or if there is a proportion between Girder/ joist profile depths that assure no LTB would occur.
Thanks.
Thanks.
