lateral wall support
hayeska
46
This is a question regarding the lateral support of an interupted gable wall.
This is a residential design with a 7' wide fireplace/chimney extending above the roof.
The roof is a vaulted ceiling and the stone veneer is to be fully exposed.
The gable end walls also have windows, limiting shear capacity.
The code requires a 2" clearance to combustible wood framing.
Question: Would there be an issue regarding thermal conductivity using steel clips to connect/brace the wall to the CMU ?
(Reinforced CMU is adequate to resist applied shear load.)
If you have any concern about it, just use a korolath shim between the CMU and the steel clip as a thermal break.
