Law defined spline (Law Curve) NX12
SiW979
804
Hi All
Would anyone be able to help me with the expressions I would need to define a law curve with the same form (size not that important) as the attached example please?
Many thanks in advance.
Best regards
Si
NX7.5 NX8.5 NX9 NX10 NX11 NX12
Technical Manager
One PLM Ltd. (Formerly Majenta and Cutting Edge Solutions)
 https://files.engineering.com/getfile.aspx?folder=6831067b-784c-4139-9067-1dc007371869&file=law_curve.prt
I can't open the file, I'm on NX11. Can you post an NX11 version or maybe just a picture?
No, i do not have a solution, but i have a screenshot :)
I highlighted the spline part of the entire composite curve, i imagine that Simon wants the entire 360 degrees as a single law curve.
Tomas
HI mmauldin
Thanks for the examples, I'm struggling to see how to get the Zt to alter in the second example, what do you need to change edit the amplitude as the wave in the law curve sketch is defined by p10? What does that huge expression for zt actually control and how do you make it take affect?
Best regards
Si
Technical Manager
In the second example , the expression Zt isn't used at all. ( probably left from example 1)
The Z-function of the law curve is entirely driven by the sketch, change the sketch parameters and the law curve will update.
Tomas
Thanks Tomas, makes sense :)
Best regards
Si
Technical Manager
Yes, that last example was thrown together to show that you can control "z" by sketching any shape you wish. Might be easier than trying to generate a mathematical formula for your profile. You could even combine bridge curves with the sketch to create a pseudo "sine" curve.
