Layer Categories Only Alphabetically Listed?
SMO
73
Is there a way to turn off the default setting that is to list Category Names, for the same layer, Alphabetically?
Seems completely unnecessary.
SMO (NX11)
Don't know what you exactly mean but how would it be unnecessary?
You can switch of the Category display and then you can still see the categories in the Categories column (Not in alphabetical order)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Sorry for the slow response... let me show an example.
I would prefer: Layer 1 | SOLID,CROSS-SECTION
Instead of: Layer 1 | CROSS-SECTION,SOLID
Reason being, I might have 20 SOLID layers in a row but only 1 unique name included for each (I can search for either name and get different result, which is what I want).
But, I know this is nit picky, it would be nice if all the common names can be displayed in the same column.
SMO (NX11)
