Layer info AutoCAD 2004
breimler
15
I need some helpful advice on this one. When I pick an object in AutoCAD 2004 it doesn't give me that objects info (ie. layer, linetype, etc.) It just shows the current layer and settings. I don't know what I would have done to make it do this.
Any ideas?
Thanks,
Brad
Found the fix. I guess I should have done some more searching before I posted. FYI, the command that fixed it was PICKFIRST with the variable set to 1.
