LC 2415 A3 NT need help in IF board 1
vladz21
Computer
Feb 17, 2016
59
AMADA 2415 AIII NT C3000D
IF Board (A16B-2100-0141)
guys, I need your expertise in this one,
A/D converter alarm, I replace and check all 24V including the IC, and the alarm is still there, I replace the whole IF board, and still the alarm is still there.
I've even check the power supply PCB and the Input board and there is no problem with it. the laser fanuc control panel is not working, only the alphanumeric soft key beside the screen is responding, and beside the A/D Converter alarm there is also code 2101 circuit protector trip alarm, I try to check and figure it out, but there is no trip in all my breakers, the alarm wont move. I've been fixing this machine by my self, I have no contact with fanuc or amada.
did I miss something? please I need help guys. thanks
but sir, i dont have any cable for the ESP1&2, the picture i send is all i have, and i been using the machine since 2007, this last january when the IC of IF board gave up and 3 Relays got bad, we decide to get a new one since the old one, cant be used.
im sorry, have more patience on me, i really appreciate your help,
I am saying the there needs to be a JUMPER there. ESP1 and ESP2. Not necessary to have a cable. Just a jumper.
On the picture of the old IF board, I am pretty sure I see a jumper there. It needs to be transferred to the new IF board.
im sorry sir, the first picture i send it to you, yes it the old IF BOARD, but my intension there is to show you that at the new IF board there is a jumper attach at DIL 1 & 2, and the small jumper was on the JD1, its on the left side. but on my original setting of the IF board when i first open, it just like the way i mention and on the picture i send, one reason sir why i need to know what's is DIL1 & 2 is for? if i connected this for just an experiment i might lose the IF BOARD again or even worst,
im sorry sir, but your right i see the jumper that your saying, i just put it in the new IF board, and i trying to test it now,
i hope thats will solve the problem, thank you for you patience, i will update you as soon i have the result sir,
sir, laserninja,
thank you very much, you were right, as always, it already pass sequence 20, and tomorrow i will start aging,
