Leakage tests using air
TheLucifer
New member
Oct 13, 2003
19
Hi all,
Has anyone performed leakage tests with air on hydraulic/fuel/water system after installation? Our contractor insists that a small amount of air leakage occurs in pumps/valves/closures, and a threshold is necessary to define the amount of leakage to say that test is failed. But we've always performed leakage tests with water and there was no threshold: any leakage was a failure. I assume that the leakage from equipment is an equipment design property, but can an air leakage happen from pipe connections, couplings etc?
I can't speak to hydrol systems in particular, but we use both air and hydro for testing tubing and fittings. Considering that the viscosity of air is a bit lower than water (100 times) then yes, you can expect to find systems with zero detectable leakage in water and measurable air leakage.
Rust never sleeps
Neither should your protection
But how do you calculate the amount of reasonable leakage? is there a guideline for this?
There is an old report written by JPL;
Technical Report No. 32-926
"Basic Criteria and Definitions for Zero Fluid Leakage"
by Richard S Weiner dated December 15 1966
Prepared under contract NAS 7-100
Perhaps someone has redone this report in electronic media, or software.
