The heat exchanger is about 14 feet long, has "high temperature water" (primary side) entering at 380 F, approximately 32" head gasket diameter, 4 pass, and secondary water entering at approximately 150 F. High water temperature drop on the primary (say 200 F) and minimal temperature rise on the secondary. The head is very rigid in construction. The portion of the head where primary high temperature water enters regularly leaks because of loss of bolt tension, and the gasket blows out (not just leaks). Gasket is "corraguard" by Garlock, considered a good gasket. Has anyone heard of a problem like this before?
