teleman1952
- Mar 5, 2009
- 3
I have been using Parker 2H and 3H cylinders for years and haven't had a problem with leaking rod seals until recently. These are the cylinders that have the "Jewel" gland with the TS-2000 primary seal and Wiperseal. On the last 2 jobs we have done, almost all of the Parker cylinders have started leaking within a short period of time. All the cylinders move at a slow speed and travel in a straight line (no arcs). The cylinders we use are:
3.25" bore x 24" stroke, MT1 mount, 30 second stroke time
4.00" bore x 8.63" stroke, MP1 mount, 35 second stroke time
10" bore x 28" net stroke, MP1 mount, 60 second stroke time, with 2" stop tube
The alignment has been checked on all cylinders, there aren't any side loads, and there are no vibrations other than slight vibrations from the running machinery. I am at a loss at finding a root cause to this problem. Parker is telling me that nothing has changed with their design. Is anybody else having problems with leaking rod seals on Parker cylinders?
