Yeh, I was pretty sceptical as well, but maybe for a small blockage....
![[pig] [pig [pig](/data/assets/smilies/pig.gif)
The squealing of rubber or leather, especially in gas or air is much more likely.
The other thing about it not being a name but an acronym (it isn't) is that the vast majority of pigs don't inspect anything - they just clean or try and separate.
For separation of products in a pipeline they actually don't do very much at all. I used to work at a multi-product pipeline company who did tests between inserting spheres and pigs to separate batches and no sphere or pig.
They found it made no difference and actually stirred up deposits and basically stopped using them for that purpose. Much of the interface was actually the time taken to open one valve and close the other in the inlet manifold and the mixing of product in the manifold.
Derby Loco - How big - the high pressure system will show up a small hole a lot faster than the low pressure stuff in your street, which is odourised. The change happened in the UK because gas in Europe was never odourised in the high pressure system and when the interconnector between UK and Europe started operation, the UK was exporting gas so they had to change to meet the spec and then had to install hundreds of small odourisation plants at the main offtakes. Helicopter surveys using infrared can find them and the regular ( 5 - 7 year) internal inspections either spot the hole or should identify it before it gets to that point.
