Learning NX and building car jack
Engineer1234321
4
I am a student interested in automotive industry. I am trying to learn how to make more complex parts using NX after learning it, and I am using the project to try in this link. I am trying my hand at the project 1, and I have some issues. Could someone be able to help me? I'm having trouble in these figure P1-8, P1-9 ,P1-11 and P1-17.
This is the link: https://www.cadcim.com/siemens-nx-2020-for-designers
I have also attached the file in question
  • Project 1.pdf
and what is your problem with 1-8? Although the draftie has made some poor choices it is all there, I think.
My problem is, I have already finished doing the one on the right, the screw base on the far right of the figure, what are the other 2 for? Where do I model them and where do I put them?
What issues are you having? Is it because these are 3rd angle projection and not 1st angle projection?
I don't know where to start for figure p1-9 and for p1-11 and p1-17, I am not able to see what dimension is for what. For example, what are those dotted lines inside the screw? And for p1-11 what is the 45 dimension? I just want to know how to start
Take P1-11 as a simple example.
There is a solid cylinder with 20 mm diameter and 45 mm length.
Inside the cylinder is a rectangular cutout that runs parallel to the axial center of the cylinder. It is 10 mm wide.
Note that there are two assumptions made:
1. the rectangle is actually square, which would mean the height of the cutout would also be 10 mm.
2. the interior corners of the "square" meet at right angles.
The first assumption is reasonable - the second is not, in terms of real-world manufacturing. Those corners would all have some small radius to them to limit stress concentrations, etc.
In the right-hand image for P1-11 the dashed lines (- - -) represent the flat internal surfaces of the cutout at "top" and "bottom". The center line (- . - . -) is the common axial centerline of both the cylinder and the cutout.
For P1-17, the two vertical dashed lines represent the nominal thread depth for the thread identified in the note at right (M12 x 1.75).
P1-8 is three orthogonal views of one part. I assume you are supposed to create a solid model of it.
Thank you for the replies. I am really having trouble with P1-9. Could someone please show me how it's done? And for P1-17, how do I do the chamfer at that angle?
