JStephen
- Aug 25, 2004
- 8,685
In designing a vertical vessel with leg supports on the outside of the shell, it is possible to approach it in two different ways.
One is to assume a pinned connection where the leg attaches to the shell and then design the leg for the resulting eccentric loading that results. This will give a larger leg and smaller connection to the shell.
The alternative is to assume a fixed connection at the shell, which eliminates the eccentric loading from the column, but requires the design of the shell for the resulting moment.
In looking at Bednar's and Moss's pressure vessel books, it looks like both use the first approach.
However, when you assume lateral loads on the vessel, that seems inconsistent with the use of the pinned connection assumption.
Any thoughts on the issue? Any reason to avoid the second approach?
