We have a sheet metal roll forming machine that performs various operations before finally shearing to length, the component length is required to vary, however the component length should be within +/- 0.5mm max. The drive is hydraulic and the encoder is driven by a wheel (rubberized) mounted on a common shaft with the encoder, contact between the wheel and metal is good. We have found that the steps/mm have to be changed regularly to keep the length within tolerance, the encoder has been changed and the system checked as much as possible.
Any suggestions?
Any suggestions?
