burbfixer
Automotive
- Nov 5, 2017
- 8
I have run into a snag with component weights for my 454 project.
I am just freshening this engine, but am using new dome pistons to raise compression. I do not want to have to re-balance the stock crank, but the new piston/pin/ring assembly weighs a whopping 68 grams more than the stock components, almost all of which is the piston.
I doubt I can safely remove that much, no matter what I do, but I know I can get most of the way there if I include lightening the small end of the rod.
This is a daily driver, low rpm application - 5000-5200 max (but rarely).
Question:
In your experience, what weight difference can I safely allow here without having this thing shake too much? 0 difference? 10grams? 20? More??
Question:
