  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Leveling 1
Equestion
New member
Jan 3, 2018
12
Good day all
I am struggling to get my head around this one[ponder]
The situation is as follow;
If an aircraft is being weighed with 3 scales ( one at Each main Landing gear and one at the nose Landing gear) at a given and known angle for eg 4 degrees, is it possible to predict the GC at 0 Degrees?
I would like to know is there a way of applying maths as an iterative method to solve it?
A bit of background to why the question arose, I weighed an A/C getting the following readings:
In Situation A I got 3131 KG on the Main LG and 275Kg on the Nose LG, the angle was measured at 4.8 Degrees.
In Situation B I got 3035 KG on the Main LG and 363 Kg on the Nose LG, the angle was measured at 2 Degrees. Situation B was created by deflating the Nose LG strut slightly. See pics below to illustrate situation A and B better.
The CG height is based on the CAD models CG height.
I used it as it doesn't seem to change too much when the CG shifts to its extremities.
Any advice on further reading on M&B? especially regarding Leveling?
Life is a DIY project
if you trust CAD for the CG height, why not the CG location ?
Equestion...
One of the reasons real-world testing [such as W&B determination] is used to validate CAD models is for the intangibles. A few examples...
What is the effect of paint finishes and other variable coatings... such as fuel tank sealant, rain-erosion coatings, etc... on the real acft CG?
What is the effect of individual balancing/ballasting of each flight control surface [unique for each surface] on the real acft CG?
What is the effect of assembly shimming [solid or liquid], liaison repairs, overhauls and modifications on the real acft CG?
IF CG/weight is remarkably off-expectations [or previous measurements], then 'WHY'?
What is the affect of material and manufacturing variations, such as: raw material thickness variations, machining tolerances, etc.
Regards, Wil Taylor
o Trust - But Verify!
