A source, please, for a type of optically clear cement to glue 2 pieces of Lexan together. Water-clear, easy process (and cheap!) would be preferred. Thaks-
Found a sort of answer myself (NASA Tech briefs!) 3M makes an optically clear sheet adhesive. They are very liberal with samples and appl. data. [sig][/sig]
try EP30-3 from Master Bond, Inc. in Hackensack New Jersey.
try and get a sample.
its a high temp resistant optically clear low viscosity epoxy adhesive
