Haf
- Nov 6, 2001
- 176
I am in need of Lexan (or a similar polycarbonate) tubes with an ID of 1/8". Apparently, Lexan tubes are not made with ID's less than 1/4" (I was told this by a plastics supplier). Initial web searches seem to confirm this. Can anyone suggest a supplier?
Another option, of course, is to get Lexan rods and drill an 1/8" hole through its center. The problem with this is that I need good optical clarity on the inside surface. Does anyone know of a good (and relatively inexpensive) way to achieve this through machining and/or polishing? The tubes will be about 0.5" long with an OD of about 3/8".
I have heard of a process called vapor polishing that can be used to polish machined plastic parts, but I don't really know what's involved, how it affects tolerances, or how expensive it is. Anyone have experience with this?
Thanks,
Haf
Thanks,
Haf
