mwemag
Materials
- Mar 28, 2006
- 42
I need to calculate the minimum size of a magnet necessary to lift up tiny iron platelets at a large distance (40 cm) over an area of 1 square meter.
The platelets of 0.4 x 0.4 mm and 0.01 mm thickness weight 1.6 micro-grams. They lay uniformly distributed on a horizontal flat of 1m x 1m, each platelet spaced by 0.4 mm to the next one, forming a chessboard-like pattern on the flat. Now they all should be lifted up bei a large area magnet 0.4 meter above the flat. Thereby it doesn't mather whether they are not liftet uniformly or twist around etc., just the magnetic force must be strong enough to pull them all up.
So, if someone has an idea how to solve this calculation, I would be really thankful, since I am still quite inexperienced in magnetic calculations.
